Quote Originally Posted by Zmax73 View Post
Pete,
Had a bad fresh water fill solenoid valve. $189 ! Tried to clean it up & adjust ,but no luck. 2001 Vantare with valve located on generator side inside the water manifold & water pump bay. It`s mounted just behind the panel inside bay & relatively easy to access. Hope this helps.
I just ordered this valve today, apparently it in bay 5. I tried changing the tank level sensor as we thought it might be cooked and it controls the GND to the valve. No Joy, so now we will change the valve.
