Pete,
Had a bad fresh water fill solenoid valve. $189 ! Tried to clean it up & adjust ,but no luck. 2001 Vantare with valve located on generator side inside the water manifold & water pump bay. It`s mounted just behind the panel inside bay & relatively easy to access. Hope this helps.
