Great information,and what a great group,helping others with the trials of buses.I am needing info on the operation as to the vantare shore/gen set/inverters work/there is a large rocker switch in a side closet that says gen or shore/does it have to be manually switched back each time a change is made/I understand from reading on the forum everything goes thru the inverters/is there a switch to bypass them and go straight to gen or shore if they give problems/my gen set will not start from inside,and the light stays green when pushed/one last thing,does anyone know where to find the gold cabinet push latches,I have several in need of changing in this 98,new to me coach/
