Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 190
Thread: Bus Stands 2010
  1. #131
    Added Matt Stuller who posted on the other thread. XLII.
  2. #132
    Here's the latest list.
    Special, Jim Chaloupka confirmed, Kerrville 2 12" only
    1 Chuck & Barb H3-40 `confirmed, Kerrville
    1 Donald Hall H3-45
    1 Ken & Gwen Brewer H3
    1 L J & Vi Verderber H3 confirmed, Kerrville
    1 Ron Walker H3 confirmed, need way to get stands, special dimensions required 8" and 12"
    1 Darrell & Linda XL confirmed, Kerrville, 13" rear
    1 Jim and Chris XL confirmed, Kerrville, 13" rear
    1 John & Donna Ayres XL
    1 Kelly & Rodney Brown XL confirmed, Kerrville, 13" rear
    1 Mike Kerley XL confirmed, friend picking up Kerrville, 13" rear
    1 Tim & Mia Sparks XL
    1 Adam DeGraff XLV
    1 Andre & Ann Ducote XLV confirmed, Kerrville
    1 Bill Bunch XLV
    1 Gordon & Jennifer Deen XLV confirmed, Kerrville
    1 Larry & Teddy Beer XLV confirmed, Kerrville
    1 Michael & Dr. Vita Terry XLV confirmed, Knoxville
    1 Mike & Jean Simmons XLV
    1 Paul & Janice Horner XLV confirmed, need way to get stands
    1 Pete & EJ Petree XLV confirmed, Kerrville
    1 Ron & Suzie Hampton XLV confirmed, Kerrville
    1 Tony Conder XLV confirmed, Kerrville
    1 Bob Russell XL-II Confirmed, Knoxville
    1 Elliott & Evy McLeod XL-II confirmed, Kerrville
    1 Eric & Debbie Faires XL-II confirmed, Knoxville, special height 13" and 11"
    1 Gary & Peggy Stevens XL-II
    1 John Browder XL-II? confirmed, Knoxville
    1 Karen & Gary Swaim XL-II confirmed, Knoxville
    1 Paul Branham XL-II confirmed, need way to get stands
    1 Alan & MK Hann XLV-II confirmed, Kerrville
    1 James & Kris XLV-II confirmed, Kerrville
    1 Loc XLV-II confirmed, Kerrville
    1 Patrick & Sherry Fix XLV-II confirmed, Kerrville
    1 Jay Becker XL confirmed, 13" rear need delivery to CA
    1 Charles Brown XLII? confirmed, Kerrville,
    1 Timia? XL confirmed, needs delivery somewhere, need bus type
    1 Matt Stuller XLII confirmed, delivery location unknown
    1 Don Hall H3 confirmed, Kerrville
    I used James list and added confirmation from the posts above in red. I also added the known or unknown delivery points.
    The orders which say 13" rears are for early model XL coaches with an angle cross member in the rear. I would not recommend the use of that angle to support the coach so the stands are higher to be placed under the vertical support member. All XLII and later model XL coaches with the square tube cross member in the rear will receive 12" stands which can be placed beneath the square tube.
    I do not have reliable height dimensions for H3 coaches or Ron Walker's H3. Will those with an H3 post dimensions from the bottom of the Prevost support points (with the bus fully raised) to the ground.
    Eric and Deb, your existing stands may be able to be modified and Mango the same hold true for yours. No sense buying new ones unless you prefer that.
    For those not attending Kerrville but need your stands please see if anyone near you can pick your stands up in Kerrville or Knoxville. The freight on these is expensive.
    For those who have not confirmed, please indicate your wishes and either James or I will edit the list. I plan on releasing the order late next week at which time I will provide all the information for the checks.
  3. #133
    Sep 2009
    Anchorage
    177
    Jon,
    Could you make our set with the 13" rears? The 13" will work with our XL-II.
    Thanks,
  4. #134
    James, Tell me why, because if it doesn't work on yours there may be others equally affected. A picture would be good.
  5. #135
    Sep 2009
    Anchorage
    177
    When I raise the bus I have the clearance to put the 13 inch stands in place.
    They may not work for everyone. If you're unsure go with the 12 inch stands.
  6. #136
    I had the chance to use my stands I purchased 2 years ago and the 14 in worked great in the rear of my xl2. I raised the bus as high as it would go and ended up using 3 shims.
  7. #137
    Aug 2009
    Eureka, CA winter, Stevensville, MT summer
    6
    Do to opening a new business with my son we will not make the rally. If any one is coming towards Eureka CA and can throw them in a bay that would be great, otherwise I guess I need to cancel the order. John Ayres
  8. #138
    John, Harry is from up that way and there may be others.
  9. #139
    Phoenix - mostly
    69
    Special dimensions for my converted seated coach with no leveling system as yet are 8" rear and 12" front. My apologies for the odd size.
  10. #140
    Noted and edited Ron. Special heights are not a problem.
    H# owners........Please, someone provide reliable dimensions with the bus fully raised.
  1. Bus Supports / Stands
    By Jon Wehrenberg in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 01-01-2022, 05:10 PM
  2. 2010 Jeep Wrangler 4 door
    By ajducote in forum TOADS, TRAILERS & TOYS
    Last Post: 03-22-2010, 12:34 PM
  3. 2010 Summer travels in the west
    By ajducote in forum OVERNIGHT PARKING
    Last Post: 02-01-2010, 08:04 PM
  4. 2010 Liberty Coach
    By edsaylor in forum The Converters of Prevost Shells
    Last Post: 11-10-2009, 08:10 PM
  5. Jon's jack stands
    Last Post: 04-28-2008, 05:10 AM
Tags for this Thread
