Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 190
Thread: Bus Stands 2010
  1. #31
    Jun 2009
    Gig Harbor, WA
    340
    Lloyd, Your brackets are on the way priority mail. Now I see you have gotten some stands as well, looks like your making out pretty good today.
  2. #32
    1,154
    James, Put Chris and I on the list for a set for the Beaver 1992 40XL, "ZORRO", and thanks to Jon and his efforts.
  3. #33
    Phoenix - mostly
    69
    Default Another H3 stand order
    Jon, Please add my name to the list for an H3 set. I sure don't want to miss out a second time. I'll work on arrangements for a rally pickup and try to post an input on dimensions. Thanks for helping us all work safely.
  4. #34
    Feb 2008
    Lunenburg, NS
    515
    Thank you Elliot and Evy. It's been a good day for the bus. Eric and Deb are great and gracious friends. Please let me know where to send a check for the postage and brackets, i am happy to have them and can't thank you enough.
  5. #35
    Sep 2009
    Anchorage
    177
    Ok, so the list now stands at 14 Sets:
    Sets Requester Type
    1 Ken & Gwen Brewer H3
    1 Ron Walker H3
    1 Darrell & Linda XL
    1 Gordon & Jennifer Deen XL
    1 Jim & Kris XL
    1 Mike Kerley XL
    1 Elliott & Evy McLeod XLII
    1 Eric & Debbie Faires XLII
    1 Gary & Peggy Stevens XLII
    1 Larry & Teddy Beer XLV
    1 Paul & Janice Horner XLV
    2 James & Kris XLVII
    1 Mark & MK Hann XLVII
  6. #36
    Sep 2009
    Anchorage
    177
    Default XLVII Body Jacking Point Measurements
    I just measured the XLVII and the rear stands would be fine at 14 inches.
    The front body jacking points, however, vary from 14 5/8 inches behind the front wheels to 16 ¼ inches in front of the front wheels and that’s allowing ¼ inch below the plates to allow slipping the stands in.
    To the base of the front tow rings measures 12 ½; however, I don’t think that is the proper jacking point.
  7. #37
    Sep 2008
    836
    James/Jon, please add me to the jack stand list, 95 XL. Do I need to send a check now or wait for Kerrville....just let me know.
    Pete Petree
    Pete & EJ Petree
    Sealy, Texas
  8. #38
    Sep 2009
    Anchorage
    177
    Quote Originally Posted by Pete View Post
    Pete Petree
    You're on the list which is up to 15 sets.
    1 Ron Walker H3
    1 Jim & Kris XL
    1 Mike Kerley XL
    1 Pete & EJ Petree XLV
  9. #39
    I need an H3 owner to research the dimensions from the underside of the chassis support points, front and rear to the floor. You should not have to get under the bus to do this, but you will have to reach under it.
    Raise the bus to its maximium height and take the dimension at all four points.
    Mango,
    If you could do it also I would appreciate it. We can modify your stands to meet the dimensions.
    Truk,
    Please give me the dimensions for your bus. The early XL coaches had a minimal flat spot at the rear support points, but they also had an angle bolted to that area that eliminated getting the entire stand beneath the rear support point. If you could analyze that, let's see if I can come up with a better way to address the rear stands on the XL early models. Later models on the XL had a heavy square tube go across between the rear supports and that tube is substantial enough and directly beneath the support points to work well.
    I will get some pictures of that in the next day or so.
  10. #40
    Phoenix - mostly
    69
    Jon, I haven't got the best level floor to measure to, but I get 8 1/2" rear and 12 1/2" front, so 8 and 12 inches would be close enough for my H3. The jacking points ahead of the front wheels are an inch higher. It will be interesting to see if Mike agrees. 'Hope this helps.
  1. Bus Supports / Stands
    By Jon Wehrenberg in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 01-01-2022, 05:10 PM
  2. 2010 Jeep Wrangler 4 door
    By ajducote in forum TOADS, TRAILERS & TOYS
    Last Post: 03-22-2010, 12:34 PM
  3. 2010 Summer travels in the west
    By ajducote in forum OVERNIGHT PARKING
    Last Post: 02-01-2010, 08:04 PM
  4. 2010 Liberty Coach
    By edsaylor in forum The Converters of Prevost Shells
    Last Post: 11-10-2009, 08:10 PM
  5. Jon's jack stands
    Last Post: 04-28-2008, 05:10 AM
Tags for this Thread
