I just want to mention how dangerous it can be to manually force a downshift into a lower gear while driving in the mountians on any declining grade. As long as you know what you are doing and remain totally aware of rpm's you will be o.k. If not, the downside is a Motor that will self destruct. Pistons will hit valves,etc,etc. When manually downshifting your Governor is unable to limit your rpm's.
