Didn't know the Jake had any sensor at the gas pedal.
Always thought the Jake was controlled through DDEC, which sent a 12 volt signal to two terminals in the rear electric box which in turn energized the two solenoids in the head.
This is something a tech with a DDEC reader should check. I wouldn't be oiling or messing around under the pedal. The throttle position sensor is under there and that sends a signal to the DDEC computer.
Jon, I guess what I meant was that the Jake comes on when the pedal is in the upmost position. Since, I can often times get my Jake to come back on by "flicking" the pedal and letting it spring back up, it makes me think that my Jake is not cutting on because it thinks the pedal is not in the upmost position. See what I mean?
As for the lubricant, I was only lubing the little roller which wasn't rolling smoothly. I was careful to confine the silicone spray to the the roller axel and only used a very little. It made a big difference though. And, all of the sudden, the jake worked again.
By the way, I'm really not a very big fan of intermittent problems. My Webasto was working perfectly the other day. Now it is back to its old tricks.
I'll talk to Prevost about the Jake.
thanks for the input!
Adam
