Didn't know the Jake had any sensor at the gas pedal.
Always thought the Jake was controlled through DDEC, which sent a 12 volt signal to two terminals in the rear electric box which in turn energized the two solenoids in the head.
This is something a tech with a DDEC reader should check. I wouldn't be oiling or messing around under the pedal. The throttle position sensor is under there and that sends a signal to the DDEC computer.
