When I had a jake issue in my CC, I pulled out the schematics. At least in the case of my 93 CC, the jake required that there be a signal from the DDEC which indicated zero throttle.
This is a wild guess, but I'm thinking that if you have to jiggle the throttle position, then there is a sensor that that is either not calibrated, or is mal-functioning.
If you had a DDEC reader, I would think you could see if you're getting zero throttle?
