Good luck, Bruce.
If you happen to have any "Rescue Tape", it will hold against considerably high pressure and can be used after you crimp the offending air line(s) in addition to, or instead of, the wire ties.
Take plenty of time to secure the jacks and assure yourself that the bus is supported. We took the better part of an hour to study/jack/support the bus before anyone crawled underneath.... to make a fix that only took a couple of minutes.
Be safe and we're all hoping for a good, and final, solution
