Originally Posted by
Jon Wehrenberg
I am guessing by your description that valve is not closing. It sounds like it is bad. As stated before Prevost sells the kit to replace the valve. it consists of the valve body and all that is necessary is to remove the defective one and replace it. Two screws and a "C" ring and that's all that is required to be removed and the valve body comes off the manifold.
The new valve will have a new "O" ring to go under it, replace the two screws, put on the coil and the "C" ring and your problem should be solved.
If the converter did not modify the system that should be the valve that controls the left rear. If the leak is not too bad you can drive the coach, but be aware you will be working your compressor to keep up with the leak.
