Some have a single small screw in the center of the electrical "plug" on one end (the part with the wires)
Loosen the screw and wiggle off the plug.
Examine the valve body to discern the way in which it is mechanically mounted to the switch block, and loosen that mounting. (save all screws, as they will be needed for remounting the new valve)
Swing the old valve, still attached to the air, out of the way and mount the new valve to the switch block.
Remove the airline and fitting from the old valve. Install the existing line and fitting to the new valve. (best to have the air off), but could be done in a pinch with air in system (work quickly).
