Originally Posted by
Jon Wehrenberg
The solenoids are the coil to which the wires are attached. By energizing the wires the coil becomes a magnet and the magnetic force puills the valve open.
When the coil is de-energized the valve spring closes the valve. When the valve is closed the air pressure in the line that pushes the Norgren valve pneumatic operator is released and spring pressure in the Norgren valve pushes the Norgren valve to its normal position.
The reason I point this out is that there are several failure modes. The most likely is the valve itself leaks at the base. There are two screws (in some cases they are phillips and in others they are #10 torqs. They are under the coil and to access them pull the coil by removing the "c" ring. Tighten them. If that does not do it, remove the valve itself and see if the small "O" ring has been pushed out of place by air pressure.
You will have to do a little detective work to find the offending valve body but if it is a problem isolating the actual leak to a specific body try tightening all of them.
If they are all tight and if you do not find an "O" ring out of place then it is likely the valve itself is leaking. They can be ordered from Prevost and in your hands overnight. If you cannot live without your aux air you may have to go to Lowe's or Home Depot and plug or cap the aux air line feeding the manifold. That line to cap is the one going into the bottom of the manifold. That will allow all other aux air systems to be aired up. Until that leak is fixed and the aux air line to the manifold restored however you cannot travel. If this valve assembly leak is sufficiently large or is associated with a solenoid that affects the ride height you could have problems if you try to drive.
If you must move the coach before you repair the valve the valve that must be working perfectly is the center one in the stack. Make sure that valve is not leaking by swapping it if is is the bad one with any other. Just do not swap coils from their original positions. The center valve in your stack is the one that controls the valving to bring the ride height valves into play.
