Bruce, Your photo shows the manifold valves (solenoids) that control your leveling system. They do fail but can normally be repaired.
Before doing that however, suggest that you re-level the bus then return the leveling system to the road position and immediately turn off the ignition key to prevent the bus from returning to road height. This seems to neutralize the valves in the off position and prevents leakdown. I'm sure Jon will be able to explain why. Adding one of these valves along with some O rings to your spares kit is a good idea.
To inspect/repair the solenoid, dump your leveling system to zero then remove the spring clip under the red screw. This will allow you to slide the solenoid magnet from the valve body and making 4 phillips screws accessible. Using a #1 phillips screwdriver, remove the 2 long machine screws from the valve body and remove it from the manifold. There are a large and small O ring on the bottom of the body which should be replaced. While you have it in your hand, remove the other two flat head screws from the body and carefully separate the two halves. You will find a spring and valve seat, inspect the rubber valve surface for nicks, dirt or uneven wear, if the seat is damaged replace the valve body.
I just took some pics of the disassembly process but noticed Jim C and Gary have chipped in. Will have the photos on line in a few minutes.
