"If it feels like you parking brake is still on, even after you released it the chances are the pads or shoes are sticking to the drum or disk. This is not uncommon, especially if the humidity is high or you have been running in rain.
Rather than try to overpower this condition, just go from drive to reverse. The slight backward motion when it drops into reverse is all it takes to release everything."
Be VERY careful trying to overcome this situation by simply over-powering it. Liberty has advised me that they have seen axles break due to this.
This can occur, as Jon has said, if the bus sits for a while after the brakes have become wet due to rain or excessive moisture.
Liberty suggested that, should this occur, to engage and then dis-engage, the parking brake a couple of times, which should resolve the problem.
Glad to hear that you had a successful journey. Your bus was one of the ones that we were considering before we bought ours, and I'm looking forward to seeing it in person some day!
