Heating zones heart
Starting to make progress with my DIY hydronic system.
I purchase a used Milwaukee M12 ProPEX expansion tool sometime ago and I have to say that it is a pleasure to use.
The bus YouTube channel "Beginning from this Morning" has a video on using such a tool.
https://www.youtube.com/watch?v=siWIgm8EKkY
The not so much pleasure is that you have to visit an actual plumbers store to get supplies and forget any of the box hardware stores.
Also this method you have to use PEX A and F1960 PEX style fittings.
You can order from Amazon, but it tends to be larger quantities and generally not available for prime next day shipping. Start your search with "F1960 PEX", lowest price first.
I unfortunately ordered lots of PEX B parts which is not compatible with this expansion tool.
As part of my design I connect the pumps with 1/2 swivel adapters. So that if a pump goes bad it is easy to replace.
These swivel adapters are only economical in PEX B for about $2.00 each, verses $20.00 each as a F1960 PEX A part.
So I elected to hand crimp them with stainless steel rings. Given that I will be using 12-16 of them by the time I am done.
So off to bus to do a test fit and get ready to start running PEX pipe for each heating zone.
