Keep me on the list, will be in Kerrville. (God willing)
Pete
Pete
Confirming a set for the Deuce. I will be in K-ville.
Thanks,
Loc
Jon, Please keep us on the the list for a set for our Beaver Bus XL40, #34.
See you in Kerrville. Yep, we are skipping out of anAirstream function in Gallup, NM and coming to Texas
If my count is correct, 19 sets of stands have been reconfirmed after I posted the pricing. I will place the order some time next week for those that have reconfirmed. Once production begins I don't believe I will be able to add any stands.
For those who may be questioning the heights of the stands I am going to post the heights, and as mentioned before any height can be ordered and produced so if you have special needs just let me know.
For those not picking them up in Kerrville lets see if we can figure a way to get them to you either via a friend who can pick them up for you in Kerrville, or picking up here in Knoxville or shipping (expensive).
Jon, Plz keep me on the list, we plan to be at Kerrville. Thankx
Jon - attendance at Kerrville is uncertain for us at this time (pesky work schedule issues for Vita). However, I'd make a run to Knoxville to pick mine up, since I need to plan a trip to see Rob Russell sometime soon anyway. Would that work for you? If so, please accept this as reconfirmation of my order.
John, Please keep us on the list. We'll not be in Kerrville, but I'll send a check and find a way to get the stands to Florida or we'll come up and get them. Thanks again.
Hey Jon,
I'm still good for a pair of stands for an XLII. I am going to Kerrville but why don't I pick them up in Knoxville since I'm a neighbor just down in Sevierville, TN. I figure it will be a good reason to come visit you in knoxville and see your digs. then maybe you can come visit me and see my digs.
Cya in Kerrville,
Jon, I still want a set but will not be at Kerrville. Paul Branham '03 XLII. Thank you.
Confirmed for 40XL and plan on being in Kerrville. Thank you.
Added Matt Stuller who posted on the other thread. XLII.
Here's the latest list.
Special, Jim Chaloupka confirmed, Kerrville 2 12" only
1 Chuck & Barb H3-40 `confirmed, Kerrville
1 Donald Hall H3-45
1 Ken & Gwen Brewer H3
1 L J & Vi Verderber H3 confirmed, Kerrville
1 Ron Walker H3 confirmed, need way to get stands, special dimensions required 8" and 12"
1 Darrell & Linda XL confirmed, Kerrville, 13" rear
1 Jim and Chris XL confirmed, Kerrville, 13" rear
1 John & Donna Ayres XL
1 Kelly & Rodney Brown XL confirmed, Kerrville, 13" rear
1 Mike Kerley XL confirmed, friend picking up Kerrville, 13" rear
1 Tim & Mia Sparks XL
1 Adam DeGraff XLV
1 Andre & Ann Ducote XLV confirmed, Kerrville
1 Bill Bunch XLV
1 Gordon & Jennifer Deen XLV confirmed, Kerrville
1 Larry & Teddy Beer XLV confirmed, Kerrville
1 Michael & Dr. Vita Terry XLV confirmed, Knoxville
1 Mike & Jean Simmons XLV
1 Paul & Janice Horner XLV confirmed, need way to get stands
1 Pete & EJ Petree XLV confirmed, Kerrville
1 Ron & Suzie Hampton XLV confirmed, Kerrville
1 Tony Conder XLV confirmed, Kerrville
1 Bob Russell XL-II Confirmed, Knoxville
1 Elliott & Evy McLeod XL-II confirmed, Kerrville
1 Eric & Debbie Faires XL-II confirmed, Knoxville, special height 13" and 11"
1 Gary & Peggy Stevens XL-II
1 John Browder XL-II? confirmed, Knoxville
1 Karen & Gary Swaim XL-II confirmed, Knoxville
1 Paul Branham XL-II confirmed, need way to get stands
1 Alan & MK Hann XLV-II confirmed, Kerrville
1 James & Kris XLV-II confirmed, Kerrville
1 Loc XLV-II confirmed, Kerrville
1 Patrick & Sherry Fix XLV-II confirmed, Kerrville
1 Jay Becker XL confirmed, 13" rear need delivery to CA
1 Charles Brown XLII? confirmed, Kerrville,
1 Timia? XL confirmed, needs delivery somewhere, need bus type
1 Matt Stuller XLII confirmed, delivery location unknown
1 Don Hall H3 confirmed, Kerrville
I used James list and added confirmation from the posts above in red. I also added the known or unknown delivery points.
The orders which say 13" rears are for early model XL coaches with an angle cross member in the rear. I would not recommend the use of that angle to support the coach so the stands are higher to be placed under the vertical support member. All XLII and later model XL coaches with the square tube cross member in the rear will receive 12" stands which can be placed beneath the square tube.
I do not have reliable height dimensions for H3 coaches or Ron Walker's H3. Will those with an H3 post dimensions from the bottom of the Prevost support points (with the bus fully raised) to the ground.
Eric and Deb, your existing stands may be able to be modified and Mango the same hold true for yours. No sense buying new ones unless you prefer that.
For those not attending Kerrville but need your stands please see if anyone near you can pick your stands up in Kerrville or Knoxville. The freight on these is expensive.
For those who have not confirmed, please indicate your wishes and either James or I will edit the list. I plan on releasing the order late next week at which time I will provide all the information for the checks.
James, Tell me why, because if it doesn't work on yours there may be others equally affected. A picture would be good.
I had the chance to use my stands I purchased 2 years ago and the 14 in worked great in the rear of my xl2. I raised the bus as high as it would go and ended up using 3 shims.
Do to opening a new business with my son we will not make the rally. If any one is coming towards Eureka CA and can throw them in a bay that would be great, otherwise I guess I need to cancel the order. John Ayres
John, Harry is from up that way and there may be others.
Special dimensions for my converted seated coach with no leveling system as yet are 8" rear and 12" front. My apologies for the odd size.
Noted and edited Ron. Special heights are not a problem.
H# owners........Please, someone provide reliable dimensions with the bus fully raised.
Jon, I will be at Kerrville.
So noted...........
We definitely want a set for our H345 and will be at Kerrville. Please advise if you want a check before then. Thanks.
Bonnie
Bonnie,
You are on my list.............:D
Any chance you or Don can get me H3 stand height dimensions? Still need dimensions for the H3.
We're out of town (taking Donald's dad to MD Anderson in Houston)and not sure when we will return. I'll check when we get back and if you don't have them by then, we'll get the numbers to you.
Bonnie
Thanks Bonnie.
Tomorrow I will fax the order for stands to the factory.
Please send checks for $193 to me at 6745 Thorngrove Pike, Knoxville TN 37914
Those attending Kerrville will receive them there and the delivery cost is included. Those picking them up in Knoxville also have the delivery cost included.
Those not able to get them in Knoxville or Kerrville please see if someone in either place can pick them up for you at either location and deliver them to you. The cost to ship is expensive. Those that need them shipped let me know and I will see if the factory can ship them direct at better prices than I can get.
I am not ordering any stands for H3 buses except for Ron's because I do not know the correct dimensions. If anybody has one please measure and get back to me.
My puny H3-40 (41) will work just fine with 14" height. Thank you very much. The check is in the mail.
Thank you Jon,
Check is in the mail.
Tim Sparks
James I would like a set also H-3, I was not a member last year when the orders were taken. Thanks Jon for all you do for this group, I had posted a while back to ask if you could use the jacks for long time parking like in Fla in winter or would they be to high?
Jon, I will send check out today, I plan on being in Knoxville early Nov If you are there I could stop by and pick them up. any color fine welllll, except pink! Ha Ha
Vita and I are still trying to work it out to attend at least part of the rally in Kerrville, but at the moment, it looks less than promising. :(
If there is anyone attending from the general Atlanta area or that will be passing through Atlanta on their way home from the rally that could bring my bus stands this way for me, please let me know! Otherwise, I will make arrangements with jon to pick mine up in Knoxville at a later date.
Thanks!
Jon, Checks in the mail. Thanks again for all your hard work on this project.
Elliott
Jon I will measure my coach and send measurements, I am out of town till Sunday Sept 5th measure then. If thats to late, that's ok too. I'll still send info for you to have any way. marrying off a nephew.
I will await your measurements. Body support points, front and rear, to the floor with the bus fully raised using level-low.
Another POG H3 owner is also going to provide the measurements so this will be a good cross check.
Jon, my check for the stands went out in today's mail. If there is a drop ship option, please do that with mine, for an XLII. If not, I'll have to arrange a visit to Knoxville this fall. Thank you. Paul Branham.
Jon, did you ever get the measurements from the other H3 owner? just wondering if they are the same as mine were. Safe trip Gary
Gary,
They were close so I picked a size that works for all.
I am in Jamestown at the factory, planning on getting home late tomorrow. As soon as i can I will be posting pictures of the stands in production. They will be powder coated black (last run was gray) on Wednesday so for all practical purposes this run is complete and stands are available for all who have confirmed the order and sent the check.
They look great.
