Mike is correct Ted...
The stands are intended for supporting the shell. With the bus supported that way it can be stored with air in the suspension dumped like Dale does, It will allow you to work beneath it with no possiblility of the shell dropping down, and it still allows you to raise or lower the axles with much smaller jacks if you want to work on wheels or brakes or even air bags.
