Thank you Joe for your input. I have a different hub then the one you are showing on the pictures. I wished I knew how to post photos. Still something to learn for me. My hub does not have the small removable top peace like yours. It has a large encasing over the entire back part of the hub. I took a picture with my IPad. Also, when I removed the hub, I noticed, that the bearings had really been torqued down hard. I thought something like that should not have more then 50 foot pounds. It took some power to loosen it, but I do not know exactly how tight it was. I had no idea that it was important to know that. My old brake drums where made by Meritor and I am getting the exact same ones. I ordered them from my local parts house and will get them on Monday. I also ordered new brake shoes for both sides. These brake shoes are supposed to be a little bit different and I hope it will make a difference in braking power. At this time, I am thinking of removing the front wheels again and purchasing brand new brake rotors. Remember, I have a new rotor on my drivers side tag. I am also thinking of replacing the brake pads with the same type of lining I am getting on my drive axle.
I hope all of this will make the improvement I am hoping for. If it does't, I am really thinking of changing the front brake pods. I think they are #24 and replace them with 30th. This is just a thought at this time and I am not sure if it's even possible.
Currently I am stuck because I am out of parts and still need to replace the bags on the passenger side. The bag replacement on the drivers side is complete and it was an easy task. I will continue Tuesday, after I receive the new drums and brake pads.
Ben
