During the Tampa RV show I stopped at the Allison Transmission booth, and asked the Allison Transmission Man, the question I posed to you guys earlier in this Post.
Retarder or Jake Brake.
This information comes straight out of the Allison manual and agrees with pretty much everything everyone out there has said, but I thought I would pass on the information as it is 100% Reliable.
The cost of owning and using a Transmission Retarder DOUBLES compared to the ownership of a Jake brake. But I guess you all knew that
Fluid change using Transynd is 300,000 miles Normal Operation or 48 Months
Fluid change using TES389 is 150,000 miles using a Retarder or 48 Months
Fluid change using Transynd is 25,000 miles Normal Operation or 12 Months
Fluid change using TES389 is 12,000 miles using a Retarder or 6 Months.
The filter change is also dramatically different ( Cut in Half ) depending on Retarder or NOT.
The problems of overheating, and causing major problems apparently has been solved or eliminated, because the Allison Man said they had experienced no problems recently??? Even Rick Thompson insists on the Retarders and believes in them, and puts Retarders on all of his new Thompson coaches.
Enquiring Minds want to KNOW
Gary S
