I hooked up a Prodigy brake controller to tow my hauler. I used the connections outside next to the drivers seat (Prevost wiring, not converters). There are some open lines that run to the back of the bus so I did not have to run any wires back and forth. Look at the door panel diagram and it will tell you which ones are available. Normally, the ones with only 1 wire attached go to the control box above your engine. All wires in there are numbered.
I also used the brake and signal wires in the rear box to complete the 7 pin hookup for turn signals, brakes, and 12V feed. There should be a diagram with wire numbers that link the front and back.
I grabbed the 12V feed from the front panel. Just put a meter on some of the areas to find 12V. I think the 12V power strip is to the right side.
I had a 1995 Liberty but yours should be the same setup. It has been sold so I cannot give you the specific wire numbers I used.
I used a Ford plug from a Ford that had a towing package and ordered the Ford adapter for the Prodigy from the internet. I think it was e-Trailer site. I did that so I could use the Prodigy on my Ford van to haul the same hauler. Of course it could just be hard wired if you don't plan on using the Prodigy in another vehicle.
