Started the Generator today's manually, and then started it through the #1 Inverter. Starting it through the inverter, the AC2 light flashes and never goes solid, no A/C power, even after several minutes, then the Generator tries to shut down.
Then, started it manually, no AC in 2 lights at all, Inverter yellow light on steady inverting.
I went outside to the gen, and started it there, and checked the voltage at the Generator breaker, and it was only reading 15.4 volts. On both sides of the breaker.
Anyone have any ideas as to what to check? It seems to work at times, and other times not, which may lead to a bad relay or something. Hoping its not inside the Stator or something.
It's a 17.5 Powertech.
