Results 1 to 10 of 55
Thread: Shopping for a Prevost
Threaded View
    Jerry, with the age and the miles, its important to replace the air bags most likely. The entire air systems should be inspected. The brakes and seals should all be inspected. A full under carrage inspection should be done. Verify the age of the coolant in the radiator and the age of the transmission oil and both types that are being used. Lube and Oil , change all filters. Replace all rubber hoses and belts if possible. All batteries, and tires should be checked for age and wear. The water tank should be sanatized. Check the water pump, Hot water heater,
    Wabasto heater. Have the OTR inspected.
    Service Generator , coolant for generator, and battery.
    Check al inside and outside electrical systems.
    These are items which should be done prior to purchasing if possible or worked into the sale price.
