i have two prosine 3.0/24 inverters one has gone out does anyone know of a repair station i could send it to thanks
I had a Trace Inverter (4.0/24) repaired by Field Technical Services in Houston a few months ago.
You might call to see if he can repair yours. Call Owen at 281-561-7149.
Good Luck
Marathon XLII
To the best of my recollection, the Prosine inverters are not repairable. I have been told by Southeast Power, the place we send our inverters for repair, that the Stat-Power division of Xantrex does not sell repair boards for these inverters. If you hear otherwise, I would like the feedback. Thanks.
Ben Cummings
U.S.A. Luxury Coaches, LLC
Clearwater, FL
i found a company in mo that can repair certain parts on the prosine 3.0X24 inverter . i sent my unit in they gave an estimate of 550.00. in case anyone is looking its PCS electronics ph 573 814 3131 ask for robert
Here's Xantrex's authorized repair facilities: http://www.xantrex.com/contacts/auth...e-centers.aspx I recently used ASE Supply in Portland OR to repair a Freedom series. Based on what Southeast told Ben, you may be out of luck on repairs. It's certainly worth calling a repair center. FWIW, the repair centers sometimes have reburbished units or discounts on new units.
If replacement costs are too high, I'd suggest you consider replacing both Magnum units.
did they fix your prosine
As of now I have not gotten it back I will let you know how it plays out
We have spare Trace Inverters in stock with some parts. You can call Mike Bolf our Service Manager at 386.804.4490
