Results 1 to 10 of 18
Thread: All Bay Lights are INOP.
    Aug 2008
    Walla Walla, WA.
    504
    Gil., no I don't have the diagrams, if you could look up the board I would sure appreciate it. I understand about the light switching and have had properly working light in the past. As to the Prevost light in in the fwd panel, my CB #52 is labled to control the bay lights, when opened that CB turns off the Prevost light as well as the bay[if they were working.] I checked the mother board fuses and breakers and all seem OK.
    Apr 2012
    Deleon Springs,
    50
    I am no electric wizzard but in the past i have had problums with the bosh type relay locakate the relay for the lights and
    replace with a new one at worst you will have a spare one some are 12v some are 24v. Just an idea i have had relay problums on my bus my mower my car some times they just conkout.
    Aug 2008
    Walla Walla, WA.
    504
    Repoer, as I read the diagram, there are no relays in the bay door light circuit. Thanks for the idea however.
    Check the voltage at a light to be sure the bulb is good, next check the voltage at the switch. If you get the electrical diagram you can go from there.
    Something tells me you did not bird dog the technician during service. Bad, bad, bad!
    Jan 2007
    1,600
    Larry, I'm thinking and thinking. There has to be an easy fix to this. 1. If you open all cargo bay doors on both sides are the lights out in every bay ? 2. When you activate the cargo light switch does one of the red lights start blinking on the mother board ?
    99 Country Coach 45XL
    Jeep Liberty
    Aug 2008
    Walla Walla, WA.
    504
    Jim, There is no voltage to the lights,[all11 of them] the bulbs are OK. Yes a diagram would be nice. As to monitoring the service techs, there were 3 of them and I only have 2 eyes <G>. I'm sure something was screwed up.
    Jan 2007
    1,600
    Larry, Just went out and looked at mine. 5th card from the left, bottom bulb lights red when I push the bay light switch in. Fuse sits sideways right under the light.
    Jeep Liberty
    Aug 2008
    Walla Walla, WA.
    504
    Jim, thanks. I just looked at the 5th board and the red light comes on when bay lights are selected on. The fuse below the card is good and ALL fuses in M/B eyeball good.
    Just have to have an open just prior to the lights, they each have their own ground I believe.
    Apr 2007
    Palmdale
    28
    The last time that happened to me I ran a wire with a fuseable link in it for protection from the power source to the first light-it worked. I then found a chewed wire from some critter- fixed it and all was well-except I never found the critter.
    Aug 2008
    Walla Walla, WA.
    504
    Thanks for the info Norm[?]. I may just try your fix, as I have been unable to find the 'open' in the circuit.
