Originally Posted by
dreamchasers
Granvil,
In your model XL, if you are experiencing the leans, it is highly probable that you have a leak in one of the components in the right rear of the coach. Remember, when you turn your key off, you block suspension air in with the 5 port solenoid mounted on the rear bulkhead in front of the differential. It has been my experience that most of my leaks have occurred in fittings, not air bags or solenoids. Good advice has been given to soap all components in the right rear. By using the soapy water process to find leaks, you can find 90% of your leaks.
Remember, do not crawl under you bus unless you have supported the bus on jack stands or other type of safety supports. If your bus were to drop while you were under it, the chances of not being injured is slim.
I have learned much about the Prevost suspension system, not by choice, because I had very bad luck with suspension repairs using Prevost Fort Worth service center. The upside of this experience is I now have a very good working knowledge of the suspension system and am able to manage my leak issues.
As mentioned in an earlier post, checkout the suspension presentation I have posted. It is very informative.
Good Luck.
Hector
thanks,it turned out to be the three way valve in the rear
Granvil Tracy
2000 Vantare XLV45, S-2
