Quote Originally Posted by Liam View Post
Thanks for responding and appreciate the help but that isnt how it works with the hydro boost. They have you remove the part that would create vacuum for a normal booster. So there is zero connection to the car brake system. All the bus does is tell the AF1 to activate the little piston on the car brake pedal. So by using my foot with the car turned off, I am doing the same thing the AF1 would if the bus were at max breaking.
On yours, the bus air is used by the AF1 to generate vacuum for your booster as well as proportional control of the little piston. Totally agree on a normal setup, you have to be connected to the bus to test.
The AF1 guy said the little piston was strong enough to pull a "dead" pedal but I, a 270 pound guy was barely able to apply enough pressure. That is why Bosch has an emergency electric pump under the master cylinder. Not sure why Chevy does not.
If you have talked with SMI and can't get it going, I think you should ask for a refund and try the M&G. Sounds like that may be the ticket if you have the room to mount it.
