Quote Originally Posted by phorner View Post
Don't know if this will help in this particular situation but thought I'd pass on my experience.
Our Liberty started to fail to "latch" on occasion when connected to shore power. The problem in my case was a failing solid state relay in the Liberty transfer switch system. there are 2 time-delay relays, one for shore power and one for generator power, located in the transfer switch box in the first bay. Both relays are the same, so I swapped them to see if it corrected my problem and it did..... so I decided to replace both and keep the one old "good" one as an emergency spare.
I have posted the specifics elsewhere in the forum, so you can hopefully find it after a short search.
Hope this helps...
Paul,
Good comment!
Hector
