Got the following list of leval 1,2 and 3 service from Keith Wilson at the Nashville service center.
LEVEL 1 ENGINE SERVICE:
ENGINE SERVICE:
Engine Service (Oil Change) WT: Quarts: Reservoir:
Change Engine Oil Filters ( Yes / No )
Change Fuel Filters ( Yes / Not required )
Change Engine Coolant Level: Gallons:
Check Coolant: PH level: Freeze point:
INSPECTION SERVICE
Inspect Engine air filter ( Pass / Fail )
Inspect Engine main belts ( Pass / Fail )
Inspect Wheel seals ( Pass / Fail )
Grease drive line U-joints ( Yes / No )
Grease King pins ( Yes / No )
Grease Tie rod ends ( Yes / No )
¬_________________________________________________ ______________
LEVEL 2 ENGINE / LUBE SERVICE
ENGINE SERVICE:
Change Engine Oil: WT: Quarts: Reservoir:
Change Engine Oil Filter(s): Yes / No
Replace Fuel Filter(s): Yes / No / Not Required
Inspect Engine Air Filter: Pass / Fail
Inspect Main Engine Belts: Pass / Fail
FLUID LEVELS:
Check Differential Fluid Level: Quarts: Type:
Check Engine Coolant Level: Gallons:
Check Coolant: PH Level: Freeze Point:
Change Coolant Filter: Yes / No
Check Power Steering Fluid Level: Quarts: Type:
Check Fan Gear Box Fluid Level: Quarts: Type:
LUBE SERVICE:
Grease Front Axle King Pins: Yes / No
Grease ISS A-Arm Ball Joints: Yes / No
Grease Steering Linkage: Yes / No
Grease Brake Components As Required: Yes / No
Grease Tag Axle Lifting Rod: Yes / No
Grease Drive Line Ujoints: Yes / No
Inspect Wheel Seals (All Axles): Pass / Fail
Inspect Shocks For Leaks: Pass / Fail
__________________________________________________ _____________
LEVEL 3 FULL SERVICE / INSPECTION
ENGINE SERVICE:
Change Engine Oil Filter: Yes / No
Change Fuel Filter(s): Yes / No / Not Required
Inspect Engine Air Filter: Pass / Replaced
Inspect Main Engine Belts: Pass / Replaced
Inspect Mini Lobe Air Bags: Pass / Replaced
Check Belt Tension Air PSI: 50-55 PSI:
FLUID LEVELS:
Check Engine Coolant Level: Gallons: Freeze Point:
Change Coolant Filter: Yes / No PH Level: Additive:
Check Fan Gear Box Fluid: Quarts: Type:
Check Power Steering Fluid: Quarts: Type:
Check Differential Fluid: Quarts: Type:
Check Transmission Fluid: Quarts: Type:
LUBE SERVICE / INSPECTION
Inspect Wheels Seals (All Axles): Pass / Fail
Drain Air Tanks (Back to Front): Yes / No
Inspect For Oil Leaks: Pass / Fail
Check Hub Oil Levels: Quarts: Type:
Check Tire Air PSI: Fronts: Drives: Tags:
TRANSMISSION SERVICE
Change Transmission Fluid: Type: Quarts:
Change Transmission Filters: Yes / No
Inspect Out Put Shaft Seal: Pass / Fail
Inspect Transmission Hoses: Pass / Fail
