Larry, A few months ago when I finally got around to installing my Guest charger I had the same concern so I called Guest and they didn't really know if having two charging sources would damage the charger but they recommended unpluging the charger before starting the engine. I did however forget to unplug it once and there didn't seem to be any negative effects on the charger but it just makes sense to me to unplug it and not take a chance.
