Originally Posted by
BoaterAl
Thanks Tom,
My storage bldg. has 8 private stalls appox each 15 1/2 ft to 16 ft wide and 60 Ft long with 14 ft electric garage door. All steel built in 1999, insulated, heated with overhead natural gas heaters ceiling mounted at both ends of bldg. Inside walls separate each stall with steel panel rising from floor appox 15 Ft. Each end left open appox 6 inch. This allows the warm heated air to circulate throughout the bldg. Works very well in the winter with temp kept at appox 42 deg. Summer screened vents at each end for fresh air circulation. Coaches are not winterized. City water, sewer dump, 30 amp electric in each stall. 200 amp bldg service. Bldg set way back on lot, 10 inch concrete on inside floors, 8 inch on 125 Ft frontage apron. Lots of room for coach washing and toad hook up before going into street. I'm aware of 3 cloned bldgs with layout pretty much the same. Inside sewer is most often the non approved item using common outside dump now.
Storage of diesel pushers only.
Flying J service across the highway. Grocery, liquor, deli walking distance. Only ID on bldg is the street numbers, no signage. 100% rented 5 1/2 years, 2 on wait list.
