Mark, Per Jon's suggestion you should find a backup light terminal on the forward terminal panel beneath the driver's seat. On my '98 chassis it is terminal #39 "From Transmission Module" (check voltage). For simplicity and utility however you might consider attaching the backup wire to a simple toggle switch next to the monitor to activate the backup camera. You can use any convenient 12v source in the instrument panel to accomplish this.
