Originally Posted by
BenC
You evidently have one of the few Vantare XL's equipped with the 2-Cruisair and 1 2-ton RVAC setup that became infamous on most Vantare H3-45 VIP's of the late 90's to mid 2000's. The Cruisair Units don't have a filter that would be located at the condenser unit, only at the evaporator unit inside the coach as Seabyrd referenced in her post. The RVAC is an all-in-one unit, with an coarse mesh filter (blue material) that Vantare put in front of the condenser fins, but also the cloth filter in the return air ductwork down to the intake on the unit. If you got both on the RVAC, the only other filters to worry about (unless you just want to wash out the condenser coils of the condensors = recommended every year or two, depending on use), the only other filters are the two inside. Hope that helps. If you come to POG10, I'll be happy to take a look at the switch wiring to see about "fixing that" issue of only 2 operating at a time.
