Results 1 to 10 of 70
Thread: Slide Seal
Threaded View
  1. #29
    Aug 2009
    507
    Tuga,
    Thanks for the help. In fact yesterday I spoke with Chuck in parts - great guy, very helpful, and good prices too. The trouble is, I need to see if the Newell seal will fit the HWH-style air seal track that we have in our LXi Wanderlodges. I'm taking some measurements of my track and I'll call Newell Tech Support on Monday to see if they have any detailed numbers for their seal. Of course my seal is 480" around and the Newell seal is 495" so I'd have to cut it to fit and then use the 'splice kit' to connect the ends to form a loop. Do you know anything about the 'splice kit'? Chuck said it was a plate of steel, a nut insert, and a bolt, and that once spliced air can pass thru the spliced area and the seal can expand at the splice creating a weather tight seal. I'm mystified as to how this works! The backup plan is to gather 15 or so orders and approach Seal Master directly for a custom seal.
  1. Output Shaft Seal
    Last Post: 03-17-2010, 03:05 PM
  2. Leaking Wheel Seal
    Last Post: 07-21-2009, 12:56 PM
  3. Hub Seal Leaks
    Last Post: 08-26-2008, 09:01 AM
  4. Front Hub Seal - Adding Oil
    Last Post: 08-20-2007, 03:04 PM
  5. Bedroom Slide Seal Leak
    Last Post: 02-19-2007, 06:05 PM
