I have a Splendide Washer/Dryer combination machine in my coach, as do many other Prevost owners. We have had a few issues with the washer/dryer during this trip. The first issue involved removing the washer/dryer from the enclosure. I did not document this because it was ugly (old men and heavy washers don't mix very well). But I did get it repaired. I used a custom plywood box cut to the same height as my washer/dryer (assembled/disassembled in the rig), with plywood cut by the local Long Beach, Washington lumber yard. All I can say is "It's fixed!".
The second issue was a faulty door lock/switch assembly. These machines operate in the wash cycle with the door locked to avoid opening the door, thus spilling water.
The reason for posting this non Prevost item to inform others that access to the door switch is available without removing the washer from its enclosure (Which can be a major pain). Carefully remove the rubber gasket surrounding the opening to access the switch. Their is a wire loop holding the rubber gasket in place.
This is the switch/lock assembly ($72 from Splendide). The symptoms were the door would not open during the drying cycle unless a "sharp wrap" on the washer was done near the door lock to jar it loose. According to the Splendide technician, this is symptomatic of a switch failure(door lock was sticking).
I included this photo because we were shocked. As a younger guy, when filling up at the local service station, a service station attendant would emerge and always fill your vehicle. But, in recent years this is no longer the case (at least in Texas). However, when I stopped to fuel my jeep at an Oregon filling station, I was doing my normal activity of getting the pump ready to pump fuel in my vehicle. A attendant came out ant told me in Oregon, it is illegal for a consumer to fill their own car. Attendants had to fill the vehicles. Well, I was soo shocked, I took his picture to remember the long lost(at least in Texas) activity.
Hector
