Tuga,
Pat Sprenger would be the one to talk to.
What I was saying about the slideroom, is that, and I don't know this now, but this coach/shell may have been "born" slide-free, and either Marathon as an Out-sourced- Option or the original owner after purchas had Rogue install the slide. . This is what makes me suspicious the coach was built slide-free off the line. PANTERRA COACH bought the proprietary rights when ROGUE went belly-up. So they may have info on this coach that would help educate yourself more.
Another tell-tale, is the 1st Preovst installed slided Marathons like our past Caoch which was 2001 shell, 2002 XLII had Zipdee Awnings all the way around. This style of awning would help aid to keep weather out with rubber Squeegees' sealing the slideroom. Not that the Rubber Squeegee style slideroom seal is bad, we were considering a coach, its just not a Prevost factory installed item.
Another thought, is the bay doors that swing down were either electrically driven or hydraulically driven with ram pistions. Our 1999 shell called a 2001 Country Coach XL, yes an XL 45 with 2 HWH sliderooms with rubber inner tube seals had CAFE" style bay doors on the driver side including the sewer bay, similar to Fast Roger's coach #60476, and wnen one of the motors failed, you have NO access.. Something else to consider.
And finally, I see the auction has ended, no wonder, the buy it now price, is 100,000 too much IMO.
