Greg,
As Brian mentioned, its seems simpler to replace the entire valve when needed, thus assuring all components are new. A comment worth mentioning, when reinstalling the pneumatic fittings into the new Norgren valve assembly, take extra precautions to assure you use thread sealant to assure you do don't create minor leaks in the fitting connection. Jon has stated that he prefers using a liquid thread sealant and has good experiences with it. I have used Teflon tape for many years in industry on connections involving hydrocarbons gases with success. I think both type of sealant work satisfactorily.
Let us know what you found leaking? With the complicated suspension systems and aux air systems on our coaches, any knowledge of potential leaks spots is a benefit.
Good Luck.
Hector
