Originally Posted by
GDeen
Jon,
Good treatise on the computer age in general, and models to predict performance....
Keep in mind though that I am talking about the Smartire sensor, which is in fact banded to the inside of the tire on the OD of the wheel. It should get a much more accurate temperature reading than one that is spinning in the wind on a valve stem. It will be biased though by any heat fed through the hub assembly into the wheel I would think.
All the algorithm does is ensure that the PV=znRT equation is reflected in the increase/decrease in tire pressure with temperature. EG, as the wheel rolls and flexes and heats up, what is the expected increase in temperature and corresponding increase in pressure. An alarm is sounded if the change is outside of the predicted range, which I think is pretty good stuff.
We inflate tires to a cold rating at 60F because that is the benchmark. What pressure should correspond to 125F that is correct inflation at 60F? Is the tire experiencing excessive flexure and corresponding heat due to an underinflation that occured after you cold check pressure that morning from a nail you picked up? With multiple variables in play, I can't figure that in my head so it is nice to have a microprocessor figure it out and alarm you that something may be going wrong with your tires. That is really all we are talking about here.
As to the 188 degrees, my main point is that is their pre-set upper limit which I assume is based on some sort of data where one should become alarmed. The value is adjustable by the user, and I have changed mine as I have not seen temps anywhere near that high.
As an aside, one of my buddies is a PHD in EE and circuit design. He was showing me a sensor the other day that is about the size of a flake of glitter from one of Loc's club shirts that has a 3 dimensional accelerometer, temp sensor, and 24 bit microprocessor. Pretty incredible stuff. If you got'm, use'm....
Lew would love this post!
