Cruise Airs have the condensers mounted in the belly of the bus and the hot air exhausted from the condensers typically blows out beneath the bus. Depending on if or how the baffles are pointed you may or may not get the warm air blown on you.
Keep in mind the complaining about warm air blown on his ankles from JDUB is coming from a guy who keeps buying coaches whose generators are located in the front bays and the hot air coming from them is blowing a hurricane of warm air up his skirt. If he had just gone and bought a Liberty the complaining he is doing would not have happened. And as long as I am finding fault with his complaining, it must be a converter thing if his Cruise Airs blew cold air on him inside the coach. A well designed coach would evenly disperse the air flow so it did not create hot or cold spots. That's what you get when you shop for price and not quality.
