Anyone have a source for discounted DD parts? I need the accessory drive kit, mine is leaking. The original part number is 23518333, but that part now shows up as R23518333 which means rebuilt I think.
Didn't you meet the parts manager for United Engines in OKC? I'd start there.
Tom,
Mine was leaking also. I replaced the seal and all is well. I purchased the seal from United Engines in OKC. The seal was less than $10.
I think seals are always at risk of leaking on a rear engine drive. While driving in the rain, their is a storm of grit in the engine compartment.
Tools required is a pulley puller and torque wrench for the big nut on the end of the shaft. I replaced the seal while the assembly was mounted on the engine. Easy!
Hector
