Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Double Header - Prevost Ft. Worth / Marathon Grand Prairie
    This is an incredible sequence of events. I am more than impressed with all of the parties involved. Kudos on a well planned service event.
    Tony and Jenny Conder
    Abilene, Texas
    2008 Marathon D/S XLII
    2017 RAM 1500 4x4
    Feb 2009
    Austin, TX
    963
    So when the throne is removed what is left to keep the anacondas from escaping? Set a dope bucket over the hole?
    Nichols Hills
    2,465
    There is no hole. That's the problem. This new technoturdomatic reduces every taco converted deuce into liquid that flows down what looks like a 2 1/2" rubber hose. That way, you can theoretically repeal some of the anaconda laws of physics by placing the toilet anywhere you want and just running a hose to the black tank.
    Old design - figure out where black tank fits, place toilet directly above it, design the rest of the coach around it.
    New design - design coach how you want it, install turbo-chop-o-matic wherever you want then run hose to black tank.
    So basically you are saying your previous coaches were kind of like sophisticated outhouses, while your current coach, which took you about a day to plug up has moved into the modern world with indoor plumbing?
    My concern would be if I were able to cause the turdomatic to fail so quickly, what must I do in the future to prevent a repeat performance? I would suggest a diet which tends to produce smaller Anacondas or.......never mind. You get the picture.
    Feb 2006
    Bristol, Tn
    1,647
    Is that Blender a Kitchen-Aid or Ronco-matic ?
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Nichols Hills
    2,465
    Hence my post. I'm saying your coach was designed around the location of the crapper where this coach seems to have no similar restriction.
    I also said it would handle "organic" material - so a double rest ring anaconda is fair game. However, feminine hygiene products are not. So the problem is how to keep every chick on "Code Red" the hell away from my bus when they need to tinkle.
    Mango Mike spent an hour driving back from work last night offering me suggestions between fits of laughing till he cried to angst over how he could use this in the future to somehow cause me offended grief. We may have a round table discussion about this at POG X.
    Just to set the record straight, you cannot lay claim to toilet placement flexibility.
    My Liberty and many others like it have toilets located some distance from the receiving tank, a feature made possible not only by excellent plumbing system design, but by a HeadHunter toilet which in concert with said design evacuates Anacondas and delivers them to distant receiving tanks. And the toilet does this without moving parts in the flow path. Unknown to me however is if there is a working limit. Thus far, with the exception of a flush valve that failed to stop the flow of water on one occasion, we have not had to need any other repairs or toilet removal. Must be a Marathon thing.
    Default Priorities
    So, the high selling point for Jdub was the Veg-a-matic John? We all have our priorities.
    It's not a Marathon thing Jon, remember the Royale, then remember the previous Marathon and now the latest Marathon with the Binford 6000 Turd-A-Nater. All these great buses had the same issue, the Crapper gave Jdub problems. My understanding is NASA is at work with a possible solution!
    Here's his Buddy Mango helping with another Crapper malfunction and plugged hose!
