Of coarse everyone is making good points, not necessarily a negative vote on the coach but things to look out for when doing an inspection. Paperwork is what your after with a used coach when you don'thave a manufacturer in buisness to support the coach any longer. Certainly Prevost in California would be one company that coulld check out many of the chasis issues. You did'nt say if the slides were Prevost or another convertors. If they are air seals made by prevost then they should not be much older than 5 to6 years in my opinion. After that, they need replacing with a newer generation of seals.
Any Detroit/Allison Service Center will be capable of inspecting both the engine & transmission along with the coolant and auxilary equipment on tthe engine. Definately have them run the codes.
All under carriage supports , steering, axles, brakes, bearing sels, shocks, mufflers, etc. could be inspected by a certified mechanic for buses or Tractor trailers.
A coach which is 10 years old and has very few miles can be a great find but if it was used contiuously in a parked position for living then the interiors and the workings of the Coach systems may need changing out.
