Results 1 to 10 of 10
Thread: Posting a Picture
    3,782
    Default Posting a Picture
    OK, here goes:
    1. At the top of the post screen is a tool bar, click on the paper-clip
    2. The file upload manager comes up, click the "Add Files" right top corner
    3. A box pops up that says "upload files from your computer", click select files box
    4. After you select your picture file, the pop up box comes back up, click upload file
    5. Your picture will show at the bottom of the page as "attachment", close the page
    6. Now your back to the post screen
    7. Go back up and click the paper-clip, a drop down box appears, click your file
    8. Your picture will now show on the screen as [Attach]XXXX[/Attach]
    9. Now preview your picture, right bottom near the "submit thread" and if ok, submit
    If you did it right, you won't see the above Taco Twin!
    Skiffer - If there is a shorter way, jump in here...
    Lightbulb
    OK, here goes:
    I skip steps 7,8 and 9 and click, Submit Reply, or Preview Post, if deemed necessary!
    I guess I only skip step 7 & 8.
    Jan 2007
    1,600
    Thanks guys, I'm trying.
    99 Country Coach 45XL
    Jeep Liberty
    Dec 2005
    Newcastle, Maine
    772
    For those of you having trouble posting a picture we think we have (finally) found a fix. These folks get a Pop-up asking them to provide a URL where the image resides instead of a Pop-up allowing them to to browse their computer and find the desired image.
    This should solve that problem:
    Go to Settings (upper right) > General Settings (left hand column) > Miscellaneous Options > Message Editor Interface and set that to "Enhanced Interface - Full WYSIWYG Editing" Make sure you save your changes.
    I can still search my computer. I have no URL for my photos because they are all on my computer.
    That's ice accumulating on the wings during a puppy transport.
    Oct 2010
    Scottsbluff, NE
    137
    See if this works?
    Wilsonville, OR 97070
    852
    Kevin I see a ladder against the coach. Where do most POGGER's lean the ladder? I have been lean it against the awning so I don't scratch the paint job. Right or wrong?
    Greg
    Oct 2010
    Scottsbluff, NE
    137
    I drape a rubber backed throw rug under the extension Ladder. The rubber back adhears to the body and cushions the ladder. I really don't like to apply uneven pressure to the awning cover.
    Kellerman Guest
    Unable to open miscellaneous tab. Word is there but will not open.
    On my system miscellaneous was not a tab, but a heading with several radio button click-able options right below.
