I didn't have the exact same problem, but for what it's worth: I had a problem with piping from the water tank to the Head Hunter pump. It leaked water ever so slightly. When the water level in the tank got down to approximately 30% through general usage, the water leak would turn into an air leak and the pump would lose it's prime and keep cycling trying to build pressure until the automatic shut off took over. In my coach, the water line on the suction side takes a 12" vertical loop to accomodate a small filter. The leak was in this area and easily fixed. Check for a small leak around your new pump. I also agree with Jon that it sounds like your problem also might be in the flush valve.
