What would the best route to M&G Brake in Athens,TX be from central Dallas.
Looking at I-20 to SR-19 and in, or SR-175 to SR-19 and in?
Thanks, JIM
Thanks, JIM
Google maps recommends the following routing:
5. Take the ramp on the left onto I-30 W 1.2 mi
6. Take exit 47B to merge onto I-45 S toward Houston 1.0 mi
7. Take exit 283B to merge onto US-175 E/ S.M. Wright Fwy toward Kaufman Continue to follow US-175 E
68.4 mi
8. Turn left to merge onto TX-31 E/ TX-7 Loop E/ toward JacksonvilleUS-175 E 1.5 mi
9. Slight right onto the TX-19 N ramp to Canton 0.1 mi
10. Keep right at the fork, follow signs for Downtown and merge onto TX-19 BUS
Depending on your starting point in Dallas, it should be about 75 miles, give or take.
Thanks for all that work Michael, I have the route. What I was looking for was road condition, something from a local or recent traveler or some comment like, stick to I-20 US-175 is not fit for bus travel or..........................
JIM I see this thread posted a day late??????????????
Jim, you may still be having problems, I noticed my sent message on this thread (#3) of yesterday has dissappeared. Hmmm just thought I would let you know.
Jim,
I took my bus down to M&G this Spring, used 175. It's a good road, no problems. As a side note I find the M&G System easy to hook up and as far as I can tell it works well. I pull a Jeep Wrangler so if it wasn't for the rear camera probably wouldn't know it was back there. Also I don't know what toad you are going to get done but you might ask them if they have a rebuild available for it. They had one for mine and it saved me a couple hundred bucks. I believe a rebuild is as good as new.
