Originally Posted by
Jon Wehrenberg
Fred, Just a comment on the Cruise Air loads. Each of mine draws approximately 13 amps. Start up the current draw may spike at as much as 35 amps or thereabouts, but it is momentary. These values are at 120 volts, at lower voltage such as on some poor shore power outlets you will see higher amps.
Shore power is 50 amps at 120 per leg or 100 amps at 120. Our 20 KW generators actually make more power available (167 amps) so running four cruise airs at one time will not even be a challenge. If your generator bogged down under that load it is likely it has only seen light usage. If you run it often under reasonably heavy loads it will clean up the carbon from running lightly loaded and it will perform much better. Don't be surprised to hear and feel it stumble as you load it up, but expect its performance to be smooth and powerful as it gets more and more exercise, especially heavy loads. Avoid running a generator for long periods lightly loaded.
Even when hooked to 50 amp shore power running all four Cruise Airs will be a challenge. If you have the HW heater it will draw about 9 amps. Just the refrigerator and the typical small loads we never think about will add up to about 5 amps, and if throw on a bunch of lights your inverters will ramp up the charge to your batteries and can easily add 15 or 20 amps to your current draw. With four Cruise airs running on shore power you can see how easy it will be to trip a shorepower breaker.
I limit my current draw by managing my power to a maximum of 40 amps, aiming for less if practical. 50 amp breakers (all size breakers actually) are good for continuous loads up to 80% of their rating, and over that the risk of tripping a breaker goes up significantly. So whenever I am in doubt about the shore power I do not hesitate to use the generator because it will give you about 83 amps per leg.
