Results 1 to 10 of 20
Thread: H3 main door lockout issues
Threaded View
  1. #5
    sawdust_128 Guest
    Here's the update and the rest of the details.
    This is the cleaned and reassembled door opener mechanism and deadbolt assembly.
    From the outside. looks good as new.
    Here's the before. This also shows where to drill and where not to drill. Stay to the left
    In this picture, you can see the linkage that has to be lifted to release the door latches. Stay away from the center ot the handle assembly. I'll address this in a bit.
    What's not right. When the new assembly arrived, all looked good. I reassembled the door and hooked up all of the linkages and when I started testing, nothing worked. Bad feeling. When I checked, I found that one of the linkages was now about 3/8 inch too short. Disassembled everything and found that this supplied steel plate (lableled !) in the next photo was different than the original. A small difference, but enough to cause a misallignment of the linkages. Swapped this for what was on the back old handle , reassembled and everything worked fine. See, this plate is in the center of the handle and in case you need it, you don't want to have drilled holes in it.
    Just a couple of other points:
    There are two door latches. One is mid-door at handle and lock height, the other is art the top corner of the door. The linkages that service these both must be well cleaned and lubed in order for the opener mechanism to work correctly.
    Another issue, when you do this, examine and replace the linkage clips (black clips in the next image). I had two which were very loose and one was damaged. I don't know if this contributed to the failure of the door handle or was a result of the failure of the door handle. Either way, they need to be checked and replaced if bad.
