Results 1 to 10 of 106
Thread: Why to have your top end looked at!
Threaded View
  1. #15
    Aug 2009
    507
    From the Detroit Diesel's "EPA07 SERIES 60 ENGINE OPERATOR'S MANUAL", "DDC-SVC-MAN-0006 Copyright © 2009 DETROIT DIESEL CORPORATION".
    My 2002 Operator's Manual says the same thing:
    ENGINE STORAGE
    When an engine is to be stored or removed from operation for a period of time, special precautions should be taken to protect the interior and exterior of the engine, transmission and other parts from rust accumulation and corrosion. The parts requiring attention and the recommended preparations are given below.
    Preparing Engine for Storage
    It will be necessary to remove all rust or corrosion completely from any exposed part before applying rust preventive compound. Therefore, it is recommended that the engine be processed for storage as soon as possible after removal from operation.
    The engine should be stored in a building that is dry and can be heated during the winter months. Moisture-absorbing chemicals are available commercially for use when excessive dampness prevails in the storage area.
    Temporary Storage (30 Days or Less)
    To protect the engine for a temporary period of time (30 days or less), follow this procedure:
    1. With the engine at ambient temperature and cool to the touch, drain engine crankcase oil into a suitable container. Dispose of the oil in an environmentally friendly manner, according to state and/or federal (EPA) recommendations.
    2. Fill the crankcase to the proper level with the recommended viscosity and grade of oil.
    3. Fill the fuel tank with the recommended grade of fuel oil. Operate the engine for two (2) minutes at 1200 rpm and no load. Do not drain the fuel system or the crankcase after this run.
    4. Check the air cleaner and service it, if necessary.
    5. If freezing weather is expected during the storage period, check the antifreeze/coolant for required freeze and inhibitor protection. Add antifreeze solution to the cooling system in accordance with Detroit Diesel's recommendations. Refer to How to Select Coolant in this guide.
    NOTE:
    If an antifreeze solution is not required during storage, flush the cooling system with a good soluble oil (3% – 5% by volume) rust inhibitor to prevent rusting of the outside diameter of the cylinder liners.
    6. Clean the exterior of the engine (except electrical parts) with fuel oil and dry with compressed air.
    7. Seal all engine openings. The material used must be waterproof, vaporproof and possess sufficient physical strength to resist puncture and damage from the expansion of entrapped air.
    An engine prepared in this manner can be returned to service in a short time by removing the seals at the engine openings and by checking the engine coolant, fuel oil, lubricating oil nd transmission oil levels.
    David Brady
    '02 Blue Bird Wanderlodge LXi,
    Series 60 Equipped,
    Asheville, NC
