I hope every POG member is not on the phone making appointments with their DD folks.
Kevin's problem was serious and did require attention. But I would doubt that the problem is across the board. Detroit engines are used in about 30 to 35% of the trucks out there and if the problem is as widespread as this group seems to be making it it would not be a dirty little secret.
That problem does not occur gradually over time. Trust me.
When damage of that nature begins it starts very small, and its progress to the level shown and beyond that happens very fast, such as between oil changes. Once it begins, no matter how small the problem is when first detected it requires the exact same repair. You cannot just remove a bad roller or repolish a cam lobe and be done.
I may have the problem right now. I may not have the problem. Regardless of which I am going to drive my bus until something tells me I have a problem. It may be a loss of power, or it may be metal detected in my oil filters. But in the meantime the sky is not falling.
