Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Leaking Valve
    Huntsville
    3,136
    Default Leaking Valve
    My fresh water drain is leaking after I turn off the switch. I assume the valve is not closing completely or a seal is leaking in the valve. Is this valve serviceable or should I just get another? Source?
    Solenoid valves are usually serviceable. If you can find the local distributor they may have a kit.
    Some however are relatively inexpensive and it makes replacement of the entire valve a better choice. A solenoid valve is a solenoid valve is a solenoid valve so as long as you get one with the coil voltage you need, the fitting sizes and the pressure rating they are pretty generic.
    Huntsville
    3,136
    I called Grainger, and they couldn't pull it up with any of the numbers. I also checked their website and found nothing. I thought this would be a relatively easy replacement or repair, but I am beginning to wonder.
    I saw some on the internet for $40 and thought that was high, so I kept looking and started finding them for $109. Now I can't find the $40 any more.
    Sugar Land, TX
    1,307
    Dale, I just hate it when I do that ! ? Good luck finding the $40 unit again.
    Gary S.
    Huntsville
    3,136
    Jon, I looked on their site and haven't yet seen what I need. (May not know what I am looking for.) I also called them a little earlier, but they were closed.
    Dale,
    I had stuck / icky valves on my CC. I found these files somewhere online, and a local Goyen distributor had repair kits for about $6 as I remember.
    I don't happen to have their number right off-hand, but see if you can find your valve numbers in here.
    The repair kit was essentially a rubber seal and a spring. Not much too these things assuming the solenoid isn't bad.
    Darn, the second file was 1.5M which was too big for an attachment. Let me know if you need an email, or if the smaller file had your valve in it.
    Attached Files Attached Files
    Huntsville
    3,136
    Ray,
    My number was in the file. I much prefer the $6 rebuild to the $120 valve. Thanks.
    dreamchasers Guest
    Dale,
    If you find rebuild kits for the solenoids, please let me know where you purchased? I need to install kits in mine also.
    Thanks,
    Hector
    Huntsville
    3,136
    Hector, I'm going to make a couple calls Monday. I don't really know what the valve looks like inside, so I don't know what's involved in rebuilding it. If I can't find a local supplier, I'll call the site Ray sent to me. I have several of these valves, but this is the first one that has leaked. It just drips a little all the time if I have water in my fresh water tank.
  1. AC Compressor Leaking
    Last Post: 05-06-2025, 09:19 PM
  2. leaking Webasto
    By ken&ellen in forum Busted Knuckles and Greasy Jeans
    Last Post: 12-27-2009, 12:25 AM
  3. Leaking Wheel Seal
    Last Post: 07-21-2009, 11:56 AM
  4. Leaking Hub Seals
    By Lee Bornstein in forum Busted Knuckles and Greasy Jeans
    Last Post: 08-22-2008, 11:33 PM
  5. Belt Tension Air Bags Leaking
    Last Post: 03-09-2006, 08:48 PM
